OK. I recieved some of the parts for my intake so I took a few pictures and started this thread. I am building a custom turbo for my Muscle. I am using a Garrett turbo and the rest will be custom made. Here is the material I found for the intake. 10" by 4.5" tall aluminum with end caps. I may have to cut it down to 9" to fit. I will get a couple of 1" 58mm aluminum tubing for stacks and a piece of alumiumn stock for the base. I will attempt to build a mock throttle body base out of wood and use 58mm wooden dowles to fit everything for welding and to get a pwrfect fit. I will remove the sharp edges to improve air flow. It will take a while but I have all winter.
