41 - 42 of 42 Posts
Discussion Starter #41
Good stuff! Thanks vrunner for the picture and guide on how you install your shift light from autometer.
Thank you :D If I can do it I think anyone can do it if you have basic automotive knowlage. I was intimidated when I tried it, lets face it your going into the ECM which basically controls everything and your worried your gonna make a BIG mistake. Every shift light I ever seen is the same, 3 wires Red,Black,Green . so the only wire you need to "wory" about is the green wire. Switch hot Red and Ground Black. As always, read the instructions and either dissconect your battery or pull the main fuse when doing any kind of electrical work, in the Service manual it has you cutting off power for any work you do. Anyone else adding a shift light, post up photos of your work :moped:
Seeing if this thread is still around, what wire did you tap into for the tach signal on the ECM harness?
41 - 42 of 42 Posts
