the biggest factor producing the high speed front end shake/wobble is the fall away IMHO.... other things are in play, like tire ballance and air pressure, etc
I was pretty unhappy with my HS shake untill I lowered my front end (slide tubes up tress 1" or slightly more) on an F with the inverts this may be impossible
the fall away can be 'tightened' a little or a lot, some bikes come straight from factory with a sloppy head bearing setup, you can start by getting the bike up off the ground and checking the fall away, if it's 'loose' get it back to spec, go for HS ride and if the shake is reduced but not eliminated you can thighten it up some more, but caution! if you tighten the head bearings down too much you can cause more problems by destroying the bearings
I recently rebuilt my front end and am having a HS shake again so I will be adjusting the fall away this week
