2004 VRSCB High/Low Beam Modification
I though I'd post up a modification I did today. The inspiration comes from RJ and a few other members here. The idea is to have the low beam operate normally. Then when you switch to high beam, the low beam remains lit providing "more" light, per say. I haven't tried this out at night but it really lit up my garage in the day light. I think this is an easy quick mod anyone familiar with simple soldering/wiring techniques. Thanks RJ for the idea! On with the pics...
THIS WORKS ON 04' VRSCB and similar headlights....
rjrivero said:1. If you are using the HD garage door opener, don't bother doing this. It won't work with the opener.
2. If you take apart the hand control connector itself, you can solder a 16g or 18g wire directly to the crimp of the Deutsch connector and you don't have to worry about weather or not your taping job will be good. Not to mention a few seconds to take this jumper off if you ever need to.
RJ
