So due to a story not worth getting into, I have replaced my throttle body assembly. I had been having some issues with the bikes performance etc and was going to replace the IAC motor anyhow. Since replacing the TB's, the bike idles @ like 2K? I have adjusted the cables, checked the IAC and all is good. Can't say the bike runs great because I keep throwing the CEL like crazy. Code says P0131 which I have searched, however think that there is a faulty ground or something somewhere, or it could be a bad o2 sensor as it suggests. Going to investigate that. Other than that, the bike actually performs well. Stock everything except; Trask/Intercooled, TMAX (all firmware is up to date). The only logical solution is the idle set screws and based on what I have read, I don't want to F with them unless that is what undoubtedly needs to be done. TIA for any rec's.
