Help.....I have 06D w/vmoded pipes, K&N filter, and PC III. Running RJ's Kangaa map, and has always run great. I only have 4500 and its starting to stall after idling, and start up. Its not stalling while letting out the clutch, its when you go to crack the throttle after idling, it gives you a quick stumble and dies. Hit the start button and it starts right up. I didnt do anything to the 3 face plate buttons at the bottom of the PCIII, just loaded the map. Ive noticed the bike has a little stumble when first leaving in first gear, of course more so when cold, then warmed up. Its almost like a carbuerator on a car loading up, and then stalling when hitting the gas. Runs better when warm but it has stalled then too. I just seemed to notice it when at a long light or idling for a long period of time. Thanks in advance....
Mike
Mike
