1 - 14 of 14 Posts
i changed my oil. everything was going smooth until i had to put plug back in i tightned it but now it just spins when i try to tighten all the way.did the first time i tighten it to much?i mean i really did not tighten it that hard when i took it off it was alot harder.did i strip the plug {hopefully}did i ruin the oil pan where the plug goes in?damn some advice or whatever would help thanks
Tie One On
There have been many people here with this same problem. Do a search and you will find the answers. I cannot remember what was done to fix this. I think some have taken the pan off and retapped to a new size and others have put in a helix coil insert (I think this is what is is)
The plug is a little stiff when removing it. It does sound like you stripped the oil pan threads. The threads are a bit fragile. You may be able to find a repair kit somewhere. I know they exist because other members have done so.
Sounds like you need to remove the oil pan and high tail it to Autozone for a repair plug. The torque value for the drain plug is 25.9 Ft/lbs which is not much.
what would be the safest,quickiest way to fix and where do i buy the pan gasket,plug.this sucks middle of summer trying to save some money changing my own oil and i strip the oil pan threads.should of just payed the extra money
yeah they make oversize drain plugs you just buy them based on the size plug thats stock like a 12mm drain plug factory then you need a 12mm single oversized they are self taping they kinda like a tap and drain plug in one
if u cant find one shoot me what size you need i shoule be able to get my hands on one
i used a 17mm socket for drain plug.where do i buy an oversized plug?and do i need to take the pan off to tap it?man im not very mechanical thats why im so pist because usally i would just pay to have it done but i wanted to change my oil and it was easy accept for the over tighting of the plug.and now i feel like its going to be a while because i cant just get in for an appt at harley or my local bike shop there booked for like 2 weeks.im screwed!!!!!!!!!!!
anyone know the thread and pitch of the drain plug ?????
someone on here has to know what the thread and pitch is
Pat (Patrick!)
Dealers have stripped them too!
Discussion Starter · #14 ·
dealership pickup
well i said screw it and i had the dealer pick it up. as i thought i stripped the oil pan threads and they said they ordered it i hope its not backordered or my summer is just about over.o and toatal cost out the door is 250 and thats with the oil i bought allready.what the f---!!!!!!
1 - 14 of 14 Posts
