1 - 2 of 2 Posts
I have an 08D that seems to have a stored code (the engine light comes back on for about 8 seconds). I have the manual and it gives a procedure of having the engine start switch in 'run', holding the reset button on the IM in and turning the ignition switch to 'ACC'. You are then supposed to release the reset button (although I am not sure how long to wait before releasing) and the little screen should read 'diag'... well, it doesn't. Am I doing something wrong? Everything on the bike works perfectly there is just this stored code and I am thinking that it threw a code when I was messing with the starter/fan relays to see if one was bad (I tried starting the bike with the starter relay out). The bike does have a V&H fuel pak on it (in the ECM wiring). Any help would be great... I just want to read the code and get rid of it.
Pat (Patrick!)
1 - 2 of 2 Posts
