I am working on installing a Rick's tank. I have the rear wheel off and am about to attack the swing arm. Does the auxillary volume on the stock exhaust have to be removed in order to get the swing arm pivot shaft out? Can the auxillary volume be removed without removing the header pipes from the engine?
Brick in the wall
Just remove the heat shield and the lower mounting bracket and you should be able to get enough clearance to get the shaft out
