feef said:
you can use some quicksteel paste.Just put a small piece of quicksteel in the reflector slut in the headlight and push firmly the reflector with your fingers ,you will have more time to do than with the glue
Haven't found the reflector SLUT yet, still looking :rofl2: Just kidding!
Finally got time to work on the light last night. Took it off & manuevered the tab back in the slot, but it wasn't tight
So I took it back out & saw that the spring-like retaining feature was not providing much resistance in the slot. So I held the piece with a pair of needle nose pliers and pushed up in the 'spring feature' to provide more holding force.
It was a lot harder to push in the slot, but it is also going to hold longer. Then I took my dremel and ground a hole in the plastic similar to VotROD's post & filled in with some metal epoxy. It's drying today, I'll take for a ride tonight.
This better fix it, I'm tired of messing with it! :banghead:
