So i took the advise of buying a repair manual but it wont arrive for a few days. Instead of waiting for it can anybody tell me what the torque specs are for the front and rear rotors and do I need locative?
Brake disc bolts, front 22-33 Nm 16-24 ft-lbs
Brake disc bolts, rear 41-53 Nm 30-38 ft-lbs
Personally I would use use a light to medium strength Loctite on the bolts. Others may disagree.
My Last Ride
LocTite Blue for the bolts that you have referred to. For smaller fasteners or fasteners that can be a pain when thread lock is used then I have started using LocTite 222 (Purple). It is sufficient for preventing fasteners from turning but it can be easily defeated when you want to remove the fastener.
Ron Becker
