Killer Service Inc.
Good Luck Will!
Nice talking to you.
PM Lane for the tundermax...Lane can you help with a base map.
You can call me if you have any problems.
I am sure there are others that will help too.
So post up and we will get you there.
Check out the video links on the turbo... Link in Sig.
Rod
Friend of Max.
This is a do it yourself kind of project. You can always post pictures and questions if you run into issues. This is pretty much bolt on.
Will, You can do the install yourself. Like I said, just be patient when you do it. Isnt Max in Texas? I know there must be more turbo v-rods in Texas than up here. Call or e-mail me with any questions and I will try to answer them.
As I said the coolant line splice is just a section of radiator hose that you can get at any auto parts store. I welded up my pipe when I sectioned mine (after replacing the original that had a hole rubbed init) If you choose to go this welded route let me know and I will detail how and where I welded mine. I can also send you my T-Max map that James tuned for me.
I will answer you as quickly as my crappy phone service will allow. At this time e-mail is a better bet.
If you know anyone who does there own mechanic work they can give you a hand. Its all bolt on stuff.
