Hello-
Just installed new pipes. Everything seemed to go together perfectly. BUT it won't start up. I checked all the connections and..... nothing. I noticed the run indicater LED light on the computer goes on for a few seconds and then turns off. Should that light stay on when the ignition is turned on??
Any ideas on what else I should try? I checked connections and checked the TPS connector to make sure the spade was cutting through the wire. What now?
All help would be greatly appreciated.
Is the head light on and bright?
The gray wiring connectors that you fish under the throttle body into each cylinder.. one side is flat, the other is arched/rounded... I cant remember which, but on side is the top and the other the bottom... you may have them set up correctly (front and rear) but one or both could be upside down?
As for the LED light, it only stays on when the bike is actually running.
Also, make sure you have a good ground... if the LED light blinked on before you started the bike, I would guess its grounded well... again, my first guess is that one of the clips is upside down.
