So I just picked up a front brake master that had been stripped and chromed.
I found out the hard way that they had completely gutted the piece and had not reinstalled anything they took off it. I was able to pick up all the parts needed for relatively cheap (direct from Harley) and while the inspection/fluid window and gasket was easy to install, as well as the new "DOT 5 only" decal on the top, I did not get any instructions on installing the new piston/spring/gaskets.
Could anyone simply provide the order in which the piston kit needs to be assembled? I don't want to screw this up.
