Could someone send me a photo of what there under-pillion area looks like or where this thing is supposed to be located.
Help! i want to get my new Corbin on so I can take a ride!
Please look closely at the photos. That's not the Power Commander. You can see the Power Commander just to the left of my hand in the second photo. The item I am speaking of is a stock Harley item. The Power commander is kept under the inner fender.Thats your power commander,must people have it mounted under the Fake tank with the air cleaner is!!!!!!!!!!!!!
You the man Big Billy!Power commanders for the "R" cannot be mounted near the air cleaner because the ECM is located under the passenger pillion, opposed to near the air cleaner box. You simply have kinda wedge that in the little compartment thats right behind the gas cap...put the power commander under there too...click this link...then click on English insulation guide(for the PCIII USB)...then scroll towards the bottom for the "R" instructions...its a tight fit...but it can be done...good luck!
http://www.powercommander.com/powercommander/powercommander_iii_usb.aspx?mk=6&mdl=34&yr=2006
please let me know about the Corbin. I've been considering one...is that the "Hollywood"? if so, is it the standard, or close model? Thanks
That's the regulaer Hollywood. I'm 6' with a 33" inseam so I needed the regular height seat and, since installed a set of Nightster handle bars which have abour 2 extra inches of rise/pull-back, I like the fact that the seating area is pushed back a couple of inches from the stock seat as well.please let me know about the Corbin. I've been considering one...is that the "Hollywood"? if so, is it the standard, or close model? Thanks
stock rise although the seating position is about 2 inches backhow much of a rise does that seat give you?
I got the close solo. At 5'7 it made a difference.please let me know about the Corbin. I've been considering one...is that the "Hollywood"? if so, is it the standard, or close model? Thanks
Mine is hard as hell! How long before it gets "broken in" and did yours get more comfortable with age?I got the close solo. At 5'7 it made a difference.
here's the shot.I was told ride it until it or you gets broken in. After that it is worth the $$$. I bought one used and had to put on 1K before it really became comfortable.
We need a pic of the after wires now that you got them placed under the seat....
