Went out to take a ride a few days ago, turned on the ignition and hit the starter. It cranked for a second then everything went dead, like somebody pulled the plug on the electrical.
While I couldn't imagine a battery problem, I nonetheless hooked it up the Battery Tender overnight. Just went out to try it and - nothing. No lights in the gauges. I did manage to get a ticking noise out of the unit, though.
I'm suspecting that the problem has something to do with the alarm system. I tried the fob and it worked a couple of times - at least the lights flashed on the gauge - but now even that doesn't generate anything.
I'm now heading for my manual, but does the fob have a battery in it that need replacing maybe?
I would check the voltage of the battery. I'd also check the battery connections. If you are getting noises out of the cluster then it sounds like you have some voltage.
my guess is a connection as well. Check across the terminals. If thats good I would folow to the maxi fuse then down. Also check your frame and engine grounds.
I was having electrical problems last year. I would be riding and all of the sudden it would turn off at a stop light. The lights would come on for a few seconds when I turned on the key but it was acting like the battery was dead. But this was an intermittent problem. I would leave the bike sit for a few hours and it would be fine again. Turns out the voltage regulator was bad.
My guess is loose battery cables or a loose ground.
