1 - 9 of 9 Posts
Voluptuous 'V'
Is there any way a 2004/2005? alternator cover with a 2004/2005 new stator fit on a 2003 vrsca?... need help now Thanks.
TRANNY KILLER :)
I am pretty sure it will, but you may wanna let someone who knows for sure chime in....
TRANNY KILLER :)
The stators did change at some point... on my '04 I replaced my stator with a newer one no problem, it does have to get bolted to the cover a certain way to make it fit over the rotor properly....
Voluptuous 'V'
there is a gap approx 1/8 inch when trying to install the 2004 cover near the forward facing end.
Greg/Moderator
Could the stator bolts be hitting ? Does the new style stator use different bolts to hold it to the cover.
Voluptuous 'V'
Think I figured it out... Tried to gently tap in place (without screws) but didn't work. It just needed a little 'help' by installing a few screws at a time then tightening the cover to the motor. Hopefully no leaks afterwards...Thanks for your help guys.
1 - 9 of 9 Posts
