1 - 14 of 14 Posts
Stuck at gas station...alarm won't disarm...what's the manual override ???
Kickstart My Heart!!
Turn on IGN and hold both direction buttons until your mileage readout shows 0----- with the 0 flashing.
Use the left I believe to change the number and the right to switch to next number. Once entered just fire it up.
You need to hold both direction buttons within like 5 seconds after turning to IGN. Also if it has been flashing you may need to wait about 5 to 10 minutes for it to reset. leave it on kickstand, don't sit on it. This must be done with no motion to the bike.
Discussion Starter #4
Got it...thanks.
Yeah not responding to fob...not even to the other one I tried when I got home!
Discussion Starter #8
Swapped battery...nada (albeit the battery was effin old)
I'll buy new ones today & report back.
Had to replace both my batteries...jot down the procedure & either keep it on the bike somewhere or yourself.
coinkydink......
now thats funny.... my fobs both recently went as well ..... at the same time, but i was pleasantly surprised to find the replacements were under two bucks each from the Stealership.
It's a world plot!!
I had the same issue yesterday for the first time
Luckily I turned it off and on again and it was OK
My bike is 15 months old so may replace the betteries in the fobs as a precaution
Discussion Starter #14
It happened a week or 2 later...was fine up until then...
Took the siren out as a precaution...well see how it goes for a while...if no issues, I'll put it back on
1 - 14 of 14 Posts
