1 - 3 of 3 Posts
Okay Its Right Side Up Im Running 2/1 Rinehatr K/n Sert It Runs Nice And Smooth Very Littel Decell Pop Of Any
Friend of Max.
Looks like it goes a bit lean at 4K.
You're showing two different pulls. The one labeled RunFile_015.drf (which is older by an hour than the pull labeled RunFile_009.drf) is lean, like RJ mentioned, from 3800 to 5000 RPM. The 009 pull, although less lean than the 015 pull, is still a little lean from around 5500 to 9000.
Were there any changes in the fuel management between these two pulls?
You say: "It Runs Nice And Smooth Very Littel Decell Pop Of Any" and the latest pull with the better AFR plot also has the better HP and Torque values. I'm not sure what kind of help you're looking for. As with most Dyno plots, you're only showing WOT data so other than working on giving a little more fuel in the 5500 to 9000 RPM range, I can't think of any changes to suggest based on these Dyno plots.
1 - 3 of 3 Posts
