I had vmod build one using 2 toe shifters,it came out very nice.Broke it once on a lay down,but welded it back
together.It's been with me since 06,and as you can see no problem with the engine guard. You might consider
looking for one on ebay,and if you like I could weld it to your exsisting shifter,just need to grind a radius and weld
it up.
I believe Sharky has a product that turns your running boards into a shifter,and brake pedal you might give him a shout at ([email protected]) Roge
I just cut off the hub area then grind it to fit the radius of theThat is a nice bike you have there! I am new here and shopping for my '08 or newer DX. Coming off an FLHX, I like the heel/toe shifter. Yours looks great. Did you simply overlap the two shifters or did you butt them together and weld? Very nice job! Thanks.
Phil
