Has anyone made or does anyone make some type of heat deflectors to blow the heat from the radiator away from the rider when the fans come on? if not whats your thoughts about the idea.
hd-v-rodder said:My 2005A came with factory airconditioning. To get it to work properly, I have to pull in the clutch, shift into first gear, increase throttle while slowly releasing clutch then shift as normal. The AC works better in temps below 85 deg.
