1 - 7 of 7 Posts
I bought an LED headlight and the connectors can be plugged into the headlight harness socket housing either way, which means they can possible be connected wrong which will blow the fuses. I am looking for a connector that the lamps in the headlight use but without the lamp part, so I can use the connector and it can be inserted upside down.
Any help will be appreciated.
Thank you
Here is the connector I am looking for not including the lamp part:
Housing coming from harness (high beam and low beam wires):
I just cut mine off and swapped them for a 3way Deutsch connector. Much simpler and not possible to connect incorrectly,.
VRSC est -03
For the lazy ones:
I'm confused Knut, was this meant for a different thread?
I cut the socket end off an old bulb, removed the pins and installed the pins from the new harness into the plastic socket.
Oh- while polarity will matter on the LED if you hook it up backwards it simply won’t work. But it won’t blow a fuse.
1 - 7 of 7 Posts
