the Kid i ordered from showyo was the Alien II xenon Kit, you'll get the fairing, already with the blue side LED ligts wired. two Brackets, one sits on the lower tree is made from aluminum and holds the fairing, and a second one made of steel that sits inside the Aluminum frame and gets connected to the original headligt screws in the side. They ship the set wit a typical "custom chopper" headlight unit, which is basically a foglight and Highbeam, so you can count roadkill on the side or blind the Guy driving upfront
It basically this one they ship the kit:
http://www.motopoint-online.de/wbc....roduktdetail2.html&pid=7407&rid=488&recno=102
But as i would love to run dual, and have low and Highbeam, without running 240km/h and flipping the switch - lowbeam turns off, highbeam brights um .. roundabout 3 Seconds Darkness .. I was looking for some Headlight unit tha fit the following requirements:
1.) has to be EG Norm legal, means not only low and Highbeam, but also l/H Beam for Xenon .. big differens, of the Projector shape
2.) both headlight has - when mounted near each other not more than 140cm wide (max Size you cound jam under the fairing.
So I found two possible options, one the 38mm ShinYo you can get as high OR low beam, and is only 120cm wide (fits easy)
or go the long way and cut two 50mm DEs on each side one time so they sit flush to each other, giving you the Highbeam blind .. i did this, I just fastened the outer scres on each projector and dremeld the other side complete away, so i lost the Usage of the clamps that tighten the lens and projector. I wind a lot of carbon fiber there, and pulled tight bevor coating with epox, not nice, but works .. and is smller than 140cm.... pics follow next.
But i could think of moving the 50mm DE highbeam blinds into the 38m,m DEs .. never tried that now, but will soon.
The wiring Harnes is ok, but as i lways do i covered every cable with mesh wi9re protection sleeves, pics follos.the energy input for the low beam is wired directly to permanent 12V and the Relay coil, that triggers the hid relais ist lined up inserial with an open relais, i connected to the oil pressure switch (unter left side cowbell cover (green/yellow).
furtzer plan i have is order two ne projectors (50mmm) and not cut them, but make them somehow fit .. dunno yet. Ideas to me please.
someone want wiring instructions, just pmme.
And review my gallery from time to time
Price i paid so far, 700-800 CAD for the kit
200€ for the pair 509mm DE
100€ for the 38mm DE pair
50€ for superseal connect, cable and mil grade textile wire cover
1600 for the shop to find and fix my wiring shortage by relocating the mirror stems
*cogh*
so with cover sleeves, cable, and bits and pieces, i think about 800-1000 euro .. but its ok, and now just today i found out the original kit was designed for the "el cheapo" headlight using H3 bulbs, after dremeling the guys down for over one cm the focal center now fits excactly but will get replaced by 55w HID tomorrow .
when i have the new pair here, i will oorder a stable mounting frame for the dual HL, but I must design them so the'll fit betweem the 140 cm of the original HL mount
Check my galery for updates ...
http://gallery.me.com/downlord#100394&view=mosaic&bgcolor=black&sel=0
