1 - 12 of 12 Posts
Does anyone have this item, if so how does it work, any problems?
Part # H-D part number 91558-01
The one that intergrates into your hi/low beam switch.. Thanks
Im so tired of getting off my bike and running into the house to open my garage doore, Also I have raynor garage door openers, any problems with that?
Joel I put one on my Dad's bike and he loves it. It works with virtually any garage door opener.
Thanks Brian,
They are on ebay for $90 delivered and Im gonna pull the trigger, is it easy to install?
RhinoRD
I have one and it is easy to install.
You do have to slice one or two wires in your harness to do it. Harley provided waterproof butt connectors for this. The butt connectors have adhesive in them that seals the connection when you use a heat gun. The unit itself is about 1.5"x 3.5"x.5" I zip tied mine to the brace under the fuse blcok. There is a unit that you connect at your garage door opener or slice into your existing button in the garage. This unit has to be plugged into a outlet. I plugged mine into the same outlet as the opener and zip tied it in place.
It took me about an hour to do it. It takes a little bit to find the right wire in the harness.
It works great (no more getting of the bike to open the door.) It has a pretty good range. Almost as soon as I see the door I can get it to open.
I have this - works great from inside my garage - hopefully my bike will be done this week and I can try it from outside :D.
What -- Me worry?
:them: Love mine. If you have a metal garage door, range in front of the garage will be reduced a bit. If this is a problem, you might try mounting the receiver to the header above the door and extending the wires to your opener from there. I bought a spare transmitter that I still need to install on my Buell...
Garage Door Opener
Try Hobbit Distributing Inc
Phone # 1-800-946-2248
I bought one Micro opener for 29.95 about the size of your alarm fob.
I put mine on my clam shell,looks OK,works great and I can take with me if I'm going w/ someone else.
1 - 12 of 12 Posts
