1 - 7 of 7 Posts
Hello all... I've never been able to get the fork lock on my 02 to work... it seems jammed... I put the key in.. but no amount of wiggling or moving the fork back and forth a little bit seems to work. The lock does not even begin to move... it's not an issue with the shaft not engageing the fork..
many thanks
On Good Ol' Nbr7
OK, this may be a dumb question but which way are you turning the key once you have it inserted into the lock?
Clockwise (toward the front tire) or counter-clockwise (to the rear)?
Does it turn at all?
HoldHard
THANK YOU VERY MUCH GUYS... 2 quick squirts of wd40///wait three seconds.. give it a turn... and that old miwaukee pot metal they used just slips n slides...
many, many thanks
greg
Moderator
gthong said:
THANK YOU VERY MUCH GUYS... 2 quick squirts of wd40///wait three seconds.. give it a turn... and that old miwaukee pot metal they used just slips n slides...many, many thanks
greg
We might want to move this to the Mens Lounge.... :rofl2: :rofl2: :rofl2:
at first mine didn't want to work either. What I learned is that you have to keep pushing in on the key while turning clockwise to lock. Never let up on the pressure while you lock and unlock the fork... I never did use any WD40... but I'm sure that has to help out as well. But I think mine not working was user error on my part...
1 - 7 of 7 Posts
