1 - 19 of 19 Posts
Frankly speaking. As far as 2 into 2 sets go. The screaming eagle is the only set I find pleasing to the eye. I've thought about the V&H 2 into 1. It's sharp-looking. I still prefer the 2 tip look. Finding screaming eagles that don't look like a pack of polar bears didn't beat on them is becoming a wild goose chase. I'm pondering on having a shop cut the stock ones down. And maybe finding a slash cut tip that can be welded on. TIA.
Tab slash cut is the way to go - nice chrome or black, sounds real good ( a bit loud for me though ) and not expensive. The newer one model is repackable, saves like 10 lbs, they flow great, power increase, super easy install. Had them on my R so I ended up screwing two SuperTrapp conical outlets on the outlets to snub db's down a bit, great overall on the stock 2-1-2 pipe. The V&H 2-1 Competition pipe is very hot on the leg, very loud but makes great power, but it's a race pipe. The older original V&H # 17535 2-1 is better for a street bike but has a more restrictive, large muffler. (y):cool:
Black 2007 VRSCD
I put these on my VRSCD:
Drag Specialties Python Mamba Mufflers for 91 to 2010 FXD Dyna PN 1801-0362 (slip on) ($60.00 at Long Beach Motorcycle swap meet)
PN P542HC 3IN Muffler HS TYPE 3
PN P543RC 3IN STR CUT CASING TYPE 4
PN A276HW 1.51IN - 2.75IN SS Hose Clamp
PN P256IN 473 INS REV 1.0
I cut the 1 1/2 ends off and it turns them into just over 2 inch (about 2 inches off the length) sliced the ends, made a bracket to hang them, worked perfect.
Much much better sound and they can be LOUD if you rev it up.
New pipes:
Tire Wheel Land vehicle Fuel tank Vehicle
Stock Pipes:
Wheel Tire Land vehicle Fuel tank Vehicle
If you're interested I can look up the guy a bought them from?
A friend has the tabs on his NRS. They're loud AF.
What outlets did you buy? I was looking into the TABs until I heard my friend's NRS on the highway. Which is where I do 90% of my riding. They used to offer a baffle that made them close to stock.
Go on SuperTrapp's website get into accessories, page 6 The 3" 3 bolt open end cap brushed SS, conical. Worked real good to keep some excessive noise inside the mufflers, one on each. Raises the pitch a bit and will blow your pants around 10' behind the outlets. I finally figured out a longer muffler is the real answer. Any time you restrict the outlet with a db reducer it leaves Hp & possibly Tq on the table. My 2-1 muffler starts at the rt foot peg and stops at the rear axle with a 4" diameter and a 3.3" exhaust outlet to lower the exhaust db & frequency. Short of that something like the mufflers beast-usa installed on the stock pipe will absorb noise & still provide really good flow - (y):cool:
Black 2007 VRSCD
Looks great beast-usa ! The length is perfect and a bit longer than the TABS so probably a bit quieter - are those the same diameter as the stock mufflers or a little smaller in diameter ?
The original inlet is smaller but the pipe is the same size. So if you cut off the small inlet about 2 - 3 inches off, the pipe is the same size as the stock pipe.
The overall size is a little smaller then the stock pipe maybe 1/2 to 3/4 of an inch. I would measure both but my bike as always is in the shop. LOL :(
They are fixing the oil leak I got at the stater wire after the cam tune-up. :(
Automotive tire Hood Automotive lighting Motor vehicle Automotive design
As an FYI, I was looking for the clamps that make this look seamless, but never found them (as they are discontinued).
After years of searching, I wanted to let you know that I finally struck gold! I cannot say where I got them, but I finally got them! I will send pics of my baffled Tab slip-on's with these when I receive them next week. Stay tuned . . .
Motor vehicle Automotive design Vehicle Hood Automotive exterior
Also, if someone is looking for a unique original HD part and cannot find it, let me know. I have a source that may be able to get it. Please just provide me the original HD part number.
Happy New Year to all!
Discussion Starter · #15 ·
What tuner would you put on an 06 with TABs? My
My wife bought me TAB slip ons fir my birthday. Have you heard about the tuner company that takes your build info and maps their tuner when you order it? I swear about it here. But that thread is buried or gone. I searched high and low. I've also heard about adding O2 sensors and
Xieds. If that's really a thing I'd do it. I just want it to run good and sound decent.
Registered Insane
Two 2003 VRSCA's: CTHULHU is Black/Sterling, N/A ; EVIL TWIN is Anodized and S/C
The search bar can be difficult because it often brings up a LOT of extraneous information to sort through. Try using the + sign in front of the keywords...for instance:
+TAB +Sensors + Tuner + Xieds
BTW...I donn't know what a Xieds is, forgive me...
You’re looking for Fuel Moto.
Discussion Starter · #19 ·
Thank you. I ordered a PCV from them. Great customer service. I will do business with them again.
1 - 19 of 19 Posts
