1 - 2 of 2 Posts
Sorry for yet another handlebar question but here it goes.
I just installed the Roadster Fairing from BAD-VR on my 08 DX with stock handlbars.
In order to make it fit, I had to twist my bars back a little but the fairing still makes contact with parts of the bar where the break and clutch lever attach into.
I have two options:
1. Cut the fairing to make it not touch (scares the crap out of me to to this for some reason)
2. Get different bars.
From my research on the forum, I believe my solution would be to get a set of OEM VRSCB bars.
Can anyone confirm or make another suggestion?
I want to do this with the lowest cost possible which means I dont want bars that would require cable changes.
Thanks in advance!
Joe
I have two options:
Thanks in advance!
Joe
I would start with changing the handle bars. Post in the parts wanted section that you are looking for a stock VRSCB bar. Someone most likely has one laying around and will give it to you if you cover the shipping cost.
1 - 2 of 2 Posts
