Not sure if I like the thoughts of this mod. I believe the site says 30 seconds for it to arm, so untill you get use to it you have to walk away and waite for it to turn off? then every time you get close to your bike the lights come on so someone can just jump on and ride away?? Might be one of those "cool extra" things to have but its not at the top of my list till I learn more about it
That's not how it works. There isn't any arming involved.
When it's turned off (RUN/STOP switch set to STOP) it stays off unless the switch is set back to RUN. However, if the fob is not within range when the switch is set back to RUN nothing happens.
So if no one messes with the switch while you (and the fob) are away, when you return with the fob and set the switch to RUN, the ignition and lights turns on. If someone messes with the switch and sets it to RUN while you're away, when you return the ignition will activate and the lights will turn on and you'll know that someone messed with your bike.
Another thing; once it's turned on the fob can go out of range and the system will stay on. This is to prevent inadvertent shut down while the bike is moving. Therefore, you need to turn off the switch and walk away (out of range). This is all that's required to "arm" it.
