1 - 13 of 13 Posts
Hi all! Any tips on removing the stock grips without cutting them? Mine are stuck pretty tight. WD40 or similar? Was afraid that might make the new grip loose in not cleaned off properly. Is any lubricant needed to install the new ones, or can I force them?
Depending on the type of grips you use, those that need to be glued on the glue works as a lube to get them on. The original grip should be glued on and may be tough to get off without cutting them off.
Max
Twisted!!!!!!!
I ended up cutting them off too. It was getting late. Maybe one of those blunt cheap dinner knifes to lift it off the glue? :hmm:
They must have used a gallon of glue on mine. The channel locks (with tape and a towel over the teeth) chewed up the rubber without budging the grip. Out came the knife, it's off now.
Use hairspray !!!!!!!!!!!!!!!
c4550 said:
Thanks jlbait. I'm hoping to get it off in one piece. Any idea on what kind of glue for the new one?
I was told by a HD mechanic to use hairspray as the glue and I've used it several times, works like a charm! Fred :laugh: :laugh: :moped:
what the hell do you want stock grips for???? Use some of that moldy money and get a nice set of grips for the Rodney!
Registered Confuser
According to my dealer, stock grips are 4.95. Cut away, your never going to put them back on and it will take just a minute instead of several minutes of frustration trying to save it.
On the other hand a bike with stock grips might be rare someday..... :diablo:
1 - 13 of 13 Posts
