You encounter gravel in a turn - how do you handle it?
Just a few pieces in the road?
Much more than that! Now what?
Highlight below to find one man's opinion
You're tailing your riding buddy on a fav back road when suddenly OHMIGOSH; he's pointing wildly at gravel in the turn! He somehow makes it through (this should be a clue: he ain't exactly Nicky Hayden now is he?)... but, now warned, what do you do?
First, you're not right on his tail, correct?
Slow a little and assess your options. If the stones are few enough to count, you can probably ignore them since they're primarily a visual distraction, posing little loss-of-traction potential.
If not, assertively modify your line so you avoid the most dense part.*
If you see you still must ride through the gravel, straighten the bike and brake firmly prior to the patch; then release the brakes and ease through on a neutral throttle, delaying the completion of your turn until you're back on clean asphalt.
Then pull over and talk. What have you learned?
* If you are in a blind turn, do not consider the opposite lane part of your avoidance strategy. If oncoming traffic suddenly appears, your chances are zero to none.
Pete Tamblyn
Senior Contributor
MotorcycleMentor.com™
Pete Tamblyn
Senior Contributor
