1 - 20 of 22 Posts
Just got my V-Lux exhaust from Toxic Choppers. Not the fastest order, but Great pipes:dance: :dance: Just what I wanted. Look great sound great, lighter. I dont know what proformance it gets but more free flow the stock so A little gain I'm thinking. I going to make a Video tommrow.
Friend of Max.
They look nice. I think you'll find that you loose a bit of power with them. True duals don't perform well on this motor.
i would be a little concerned that the different length between the short rear and the long front may cause a tuning problem. i would get the A/F checked on each pipe, otherwise i like the look:2cents:
I have orered the foward control kit from V-mod because I have never like the mids. But there is no problem either on the pigs or the mids. I plan on getting it Dyno'd as soon as I get the PCIII I too have ordered from V-MOD.
I think you might lose some HP with those pipes. I heard of another guy that put something like that on his bike and ended with 98 HP after dyno (was at low 80s before tune based on dyno - could be a tale). They look great though - keep us informed of dyno numbers.
:stupid: they do look pretty cool but i doubt you're gaining anything and more than likely losing a bit. but whatever, if you like them that's all that matters.
I like them. Not very technical minded but losing power was the first thing I thought when I saw them. Anyhow, they add to this model, very smooth and cool.
I will post when I get Dyno'd, but I have not noticed any power loss. Still pulls all the way up the gears. I do have some crackling and poping now and then but hoping to get rid of that with the PCIII. I do realize 2 in 2 is not as good as 2 in 1, but these pipes were made on Matt Hotch's biker build off on dicovery channel where he was racing across the desert for speed. I don't know how much time he sent on designing them. We will see. If I'm down in the 80's I will be chasnging them.
Gone
Your running it without a FI module? I guess it is cool for a little bit but with those pipes and a K&N you have to be running crazy lean right now. Good looking pipes though
Do yourself a favor and go order a rear motor mount from an 07 DX,
p/n16299-01. When you take the mids off there is that annoying steel sleeve that they connect through and it is welded to the motor mount. It was only like $25-30 and well worth not having the eye sore.
I'm 'avin hoops
:them:
well i got my v-lux pipes today in the mail, got them one day early very happy.. alittle tricky putting them on but all in all about an hour sounds sick scott forgot to send me both baffles so right now running with none. took about 2 weeks to get them ( flat black ).. one question i have the pcIII its looking for djm file but the map he sent is a .map does anyone know how i get the pcIII to work with it.. thanks
P.S
if anyone wants a set of these pipes lmk i have some discount codes.. if you plan on going chrome i would ask for them bare and send out to a local chromer from what i see its the chrome pipes that are havin problems with time
J.P
iTrader Technician
P.S
J.P
Dude, did you have to make the same post in 5 different threads?
Good looking pipes. Dont worry about the power loss if you like the look.
You do need to get a fuel managment device of some type. ASAP
did the pcIII with the tune scott sent. so far so good no stallin or any other problems and boy oh boy loud. you want loud pipes these are the way to go not sure how to post videos and pics on this forum if someone tells me how ill post them up
J.P
1 - 20 of 22 Posts
