Vrodder since 2004
At 10,000 I don't really have any serious issues. I plan on getting the fluids changed, the plugs, have them tighten and torque everything . Check the brakes. I do have a small issue with the clutch if anyone knows why it would be appreciated - shifting from 1st to 2nd is difficult- sticks in 1st and alot of times goes right into neutral- I have to really give it a good shove and it sounds aweful. Hopefully some new fluid will help this? If not, any suggestions? Also, lately alot of back pressure in deceleration...pop, pop, pop...its pretty loud. I have Vmodded pipes with a power commander. The pipes also seem to be emitting more heat than usual around the mid area. It gets so hot my butt starts burning.....any suggestions on that one? It was never like that until the last 8 months or so. In the winter, it was flaming hot too. There is no indication of any leaks. Anyway, advice, suggestions, are appreciated! I'd like to go in with some idea of what might be going on.Thanks!
Clutch.. Try shifting at higher RPMs and see if it's different. Mine greatly improves over 5Krpm.
Check your settings on the PC... it sounds like adjustment may be in order.
Scott
There's a Thread somewhere here about disassembling the shift rod, cleaning it and re-lubercating it which appartently really helped that V-rodder.
Anyone know where this thread is?
Sanctimonious
Should get better after an oil change, If not than the Rod might need cleaning
I believe your running a bit rich
Its Summer and you live in Temecula:hidesbeh:
Vrodder since 2004
Discussion Starter #5
Thanks!
My popping was from running to lean on decel. Adding fuel to the PC at 0 and 2 throttle fixed the issue. Check your PC and make sure it didn't lose it's map if this just started happening.
