Again .....new to vrods and T/MI'm in a shitty mood so I'll bite on this as well.
CLEARLY he isn't or doesn't know how to read log data.
No shit ?If you have turbo it's normal but the front pipe should glow too.
When I ride my turbo hard, you could read a newspaper at night next to it.
Hello - If you or any readers have these EGT probes in their V-Rods can you report the temps in each cylinder while cruising at 60-70 mph?Have to respectfully disagree on a lot of that.
High EGTs typically = lean. I use EGT probes on some of my projects on a per cylinder basis as a way to find lean cylinders/injector issues/fuel rail design issues/issues during a 1/4 mile run etc.
Does red header = boom? Not necessarily, however I certainly would be logging O2 sensor data (WBO sensor if possible) when tuning/concerned about glowing headers (as the OP is). Too much data and technology on hand now a days to assume.
FYI, turbo blankets (or proper ceramic coating) are typically used to keep underhood temps manageable.
1100 °C is very bright I would sayNo shit ?
