it just started to act up. sometimes it works fine some time it does not work. i flip on the key, turn it to run, wait for the pump to prime, and hit start... it starts. then the other half of the time, i do the same process but it cranks over but will not start. if i turn the key off and back on, it will (most of the time) start.
i did run it our of gas about a month back, not sure if that could cause a pump problem?
tuner is a T-max
any ideas on where to start?
tuner is a T-max
