Sorry if this has been addressed before. Appreciate any help I can get.
Lately, my Streetrod has been difficult to start. When I turn on the start switch, the fuel pump runs and stops as normal, but fuel pressure drops to zero immediately. I confirmed this with my fuel pressure gage. The pressure goes up to 42 psi, then drops to zero immediately. That's why it cranks over several times before starting(when engine is cold). After engine starts, it shows 58 psi at idle. When I rev the engine, it drops to 50 psi just for a second or two, then back to 58 psi. When I go riding, it seems pretty much normal(at all speeds). Not sure about the psi when riding.
Why does the fuel manifold not hold pressure until the engine is running? Could it be a defective fuel pressure regulator? Thanks in advance for any suggestions.
CG
CG
