201 - 207 of 207 Posts
Need help with fuel pump inspection, or removal, gas only coming out of one fuel line ? Bike wont start but will run on starting fluid....was in storage for 2 years...could it be the injectors, fuel pump , or what ? Please help !!!!!
Where did you disconnect the lines? If you disconnect the pressure line you won't have any fuel on the return side. Are you having trouble with the bike? When you turn the key on can you hear the pump run?
Yes I did take both lines loose...had a brain fart...thought for a minute fuel should come out both nipples on fuel flange...yes the pump pumps out the outgoing nipple...but not really very robust...got a feeling its way under 50 psi...will rig up a pressure gauge and hose tomarrow and get an accurate reading....bike sat for awhile in storage...put fuel treatment in tank...not much fuel in there though...ment to fill tank and forgot....then started bike up and sucked treatment into lines and injectors. ..probly ruined fuel pump...ran for 10 min. Then quit....wont start but will run on ether...any ideas ? Anyone ?
With lines connect remove cap shine flashlight in tank turn on key and run switch look in tank for misting fuel. Most likely a split supply line from pump to flange
