1 - 2 of 2 Posts
2004 vrscb which won't start.
I have spark and the pressure at the shrader valve is 58.
What's next to check?
Will it pop if you give it fuel from an outside source? If so, unplug the injectors, put a test light across both pins and crank- the light should flicker/blink indicating you have injector pulse. If you do, the injectors themselves are probably stuck or restricted. If not- the ecm either isn’t seeing a crank signal or isn’t triggering the injectors
1 - 2 of 2 Posts
