Sharks-Parts
does someone have a front wheel inner spacer that they can measure for me? Thanks - Sharkey
Just a big ole Doof
20 mm
Sharks-Parts
correct... it is longer than 20mm - I have one and I have a DX wheel and when I install the bearings I still have way too much play between the bearings with the spacer... I am trying to be sure I have the correct inner spacer or if there is an issue with the bearing pockets.... Thanks everyone...
Just a big ole Doof
That's a little short for an inner spacer. I don't have one lying around to measure but it should be about 3 or 4 times longer than the diameter. Of course the OP didn't say what measurement he wanted, diameter, length, or both.
Ooops, he did say inner spacer. My mistake!
Sharks-Parts
diameter and ID are nil to me... just need the length... Thanks
Sharks-Parts
still hoping for a measurement.... in mm would be best ...... Thanks
Killer Service Inc.
Sharkey,
If you have the part number you can look it up in the parts book in the back and it should give you the size.
If you still can not get the size,post up the part number.
Merry Christmas My friend.
Rod
