  1. Is there supposed to be a pin on the key side front wheel? It looks like the pin that goes through the wheel has a hole in it for a holding pin? Thank you in advance.
As Ron replied in other post. No, is only a method of holding axle while tightening or loosening the nut.
Stop....put down tool(s).
Buy service manual. Read. Make sure to use a torque wrench on reassembly.
Best advice you will get as this (and basically everything else on the bike) is covered very well in the SM.
Wasn't working on it. Just noticed it. Rather be safe than sorry. Changed oil/filter, Retuned and cleaned it up. I do need to get a manual. Thank you and anybody know where I can find a radiator overfill cap?
Advanced auto parts has a radiator cap that fits exactly the same (can't recall the model as I took my old one in and had the parts guy hunt for a cap that looked the same/same pressure specs. Was about $5. From some foreign car I believe.
