1 - 9 of 9 Posts
Ride on!
Okay everybody,
It is so nice to be able to get answers to your V-Rod questions in one place. Thanks you'll, keep up the good work.
I'm putting the Metz 200 on the rear and was looking at my front tire and have decided to change it as well. What are my options? I haven't been able to find a metz in that size, 120-70-19. So who makes one? I have looked all over and don't want to go with another dumploop.
Help... thanks
:cool:
SNAFU
Metzeler makes the correct tires but for some reason they aren't on the website's fitment section. Here's an exerpt from their brochure:
ME880 SIZES
SIZE A B C D E F G H Z
100/90H18 F 2.50 2.15-2.75 102 636 494 42 130 5.5 11.02
110/90H18 F 2.50 2.15-3.00 114 657 567 42 130 5.5 13.01
120/90HB18 F 2.75 2.50-3.00 124 685 639 42 130 5.0 14.99
130/60VR18 F 3.50 3.50-4.00 125 614 551 42 168 4.5 9.92
130/70HB18 F 3.50 3.00-4.00 123 643 600 42 130 5.5 13.23
130/70HR18 "H" F 3.50 3.50-4.00 128 653 599 42 130 5.0 14.19
130/70HR18 "G" F 3.50 3.50-4.00 126 655 599 42 130 5.6 13.22
140/70H18 F 3.00 3.00-4.50 131 658 675 42 130 5.5 14.19
100/90H19 F 2.50 2.15-2.75 108 674 507 42 130 6.0 11.68
110/90H19 F 2.50 2.15-3.00 116 686 584 42 130 4.0 12.79
120/70ZR19 F 3.00 3.00-3.75 115 652 551 42 172 4.0 10.80
80/90H21 TT F 1.85 1.60-2.15 80 693 397 42 130 6.0 7.94
90/90H21 TT F 2.15 1.85-2.50 92 700 467 42 130 4.2 8.03
120/70V21 F 3.50 3.00-3.75 118 706 677 42 149 4.0 11.22
140/80HB15 R 3.50 2.75-3.75 145 619 677 42 130 8.0 14.77
140/90HB15 R 3.50 2.75-3.75 148 640 739 42 130 8.0 16.09
150/80HB15 R 3.50 3.00-4.00 148 640 739 42 130 8.0 15.87
150/80VB15 R 3.50 3.00-4.25 148 640 739 42 149 8.0 15.98
150/90HB15* R 3.50 3.00-4.00 158 662 992 49 130 8.0 19.40
170/80HB15 (WW) R 4.00 3.50-5.00 187 670 908 42 130 8.0 20.28
180/70HB15 R 5.00 4.25-5.50 178 648 882 42 130 8.0 21.38
200/70HB15 R 5.50 5.50-6.50 207 666 1047 42 130 8.0 19.62
130/90HB16* (WW) R 3.00 2.50-3.50 137 646 805 49 130 8.0 16.98
140/90HB16* (WW) R 3.50 2.75-3.75 146 665 908 49 130 8.0 17.20
150/80HB16 R 3.50 3.00-4.00 153 660 761 42 130 8.0 15.65
160/80HB16* R 3.50 3.50-4.50 162 662 1017 42 128 8.5 18.71
180/70HR16 R 5.00 5.00-6.00 175 664 908 42 130 9.0 20.28
180/60HR16* "G" R 5.00 5.00-5.50 174 629 825 42 130 7.5 17.84
200/60VR16 R 5.50 5.50-6.25 197 659 963 42 149 6.5 18.26
240/50VR16 R 7.50 7.00-8.00 240 658 1102 42 149 7.0 20.07
140/80VB17 R 3.50 2.75-4.00 144 669 716 42 149 8.0 17.87
160/70VB17* R 4.50 3.75-5.00 157 654 963 49 149 9.0 19.84
170/60VR17 R 4.50 4.25-5.50 169 639 783 42 149 7.5 14.99
210/50VR17 R 6.50 6.00-7.00 210 642 937 42 149 5.5 14.30
140/70HB18 R 3.00 3.00-4.50 135 655 803 50 130 8.0 17.45
180/55ZR18 R 5.50 5.50-8.00 183 657 827 42 172 6.8 15.19
180/55VR18 R 5.50 5.50-6.00 186 655 827 42 149 6.8 15.49
200/50VR18 R 5.50 5.50-6.50 197 659 882 42 149 6.5 16.50
240/40VR18 R 8.50 8.00-9.00 239 655 963 42 149 6.5 18.36
Note that the 200 is only V rated so don't be going over 149 mph ;)
Here's a link to the brochure and their site:
http://www.us.metzelermoto.com/product_info/pdf/m_full_line.pdf
http://www.us.metzelermoto.com/index.asp
Motorcycle Superstore has the fronts for $104. Click on M880 high mileage fronts then select the last size on the pulldown.
http://www.motorcycle-superstore.co...ment=647&division=6&Manufacturer=86&Class=280
The Rear is under their M880 XXL, it's $149
Twisted!!!!!!!
Anybody has one installed? Any pros or cons?
Is there another "preferred" front tire for the V-Rod anybody else using?
How about the construction of a Z rated tire, since most V-Rods will never see speeds in excess of 149mph for any extended period of time, including mine, will it really provide any kind of real world advantage besides it having the last letter in the alphabet:slap2: ? Will a Z-Rated tire be considered a "safer" tire. I'll do anything just so no one has to see my brains flowing out of my ears.
SNAFU
Only safer if you're running in excess of 149 MPH for more than 10 minutes at a time ;) At normal speeds there's not need to worry. I'll bet all they did with the Z rated 200 is simply test it @ a speed above 149 mph. It's probably the same tire.
Tired of the crap
eduarprmd said:
since most V-Rods will never see speeds in excess of 149mph for any extended period of time...will it really provide any kind of real world advantage
Of all the parts of a motorcycle you could save money on, I'd put tires as dead last.
The "Z" rating means that the tires have been designed and tested so as not to disintegrate when run at high speeds for extended periods. In order to pass this test, the carcass and tread have been designed to be strong enough to withstand the greater stresses such high-speed operation creates. This added strength is there to prevent tire blowout or failure at all speeds - making you much safer. "Z" rated tires are also absolutely superior in terms of performance than a lower rated model.
1 - 9 of 9 Posts
