Hi is it normal to have about 60% lever travel before the front brakes start to bite (when they do they work fine and stop the bike without problem). I have fitted new calipers, EBC pads and DOT 5 brake fluid and pressure bled them. There is no air whatsoever in the system. The old calipers gave the same problem. Is this a master cylinder issue. if so are repair kits available.
Thanks for any help you can give.
