When applying the front brake, the bike seems to shudder and wants to lose control. The pads look fine. How do you check to see if the rotors are warped? Any Help?
Use a dial indicator.This will let you know.The runout specs are in the service manual.When applying the front brake, the bike seems to shudder and wants to lose control. The pads look fine. How do you check to see if the rotors are warped? Any Help?
great tip, I'd try this first.....I have found countless times that "warped" discs aren't. Sand the heck out of them with a good aggressive paper and you will probably find that brake application will smooth right out. Most of the time it has to do with deposits on/in the metal instead of actual warping.
:them: I replaced my warped rear, but it was warped from physical damage.I have found countless times that "warped" discs aren't. Sand the heck out of them with a good aggressive paper and you will probably find that brake application will smooth right out. Most of the time it has to do with deposits on/in the metal instead of actual warping.
And just how did your rear end get warped???:them: I replaced my warped rear, but it was warped from physical damage.
Agreed! Especially if you just had a period of hard/aggressive braking and then held the brake down when it was hot like at a stop light or something.I have found countless times that "warped" discs aren't. Sand the heck out of them with a good aggressive paper and you will probably find that brake application will smooth right out. Most of the time it has to do with deposits on/in the metal instead of actual warping.
Do you mean that it was bent?:them: I replaced my warped rear, but it was warped from physical damage.
You should quit while your ahead AOW:hidesbeh:And just how did your rear end get warped???
:bolt:rofl2:
Forced Entry maybe?And just how did your rear end get warped???
:bolt:rofl2:
:rofl2:Forced Entry maybe?
