Went for a ride today and the weld where the clutch lever is is broke ? not sure if anyone else has had this issue. Can I just re order that part of the frame or should I have it ready welded. Pic is attached
Can't open the pic to see the exact spot, and the clutch lever part makes no sense but as a welder, I've not seen any part special on the vrod that a decent welder couldn't whip up a quick jig if needed, clamp it to eliminate distortion and reweld it.Went for a ride today and the weld where the clutch lever is is broke ? not sure if anyone else has had this issue. Can I just re order that part of the frame or should I have it ready welded. Pic is attached
It's the footpeg mount on the framerail (gear lever side)Can't open the pic to see the exact spot, and the clutch lever part makes no sense but as a welder, I've not seen any part special on the vrod that a decent welder couldn't whip up a quick jig if needed, clamp it to eliminate distortion and reweld it.
If anyone else needs this info the part was $368 dollars ?
I think I just hurt myself falling off my chair.
Maybe I'll just start buying up a bunch of damaged ones that would get tossed away and splice in new tubing for years to come.
