1 - 2 of 2 Posts
I'm planning on replacing the 8 socket screws that fasten the lower frame rails to the upper frame with polished stainless ones. Can one of the screws be removed at a time and replaced without supporting the lower frame rails with a jack, or should it be supported to prevent sagging when the socket screw is removed.
One at a time will be fine, make sure you anti-seize the threads on the stainless.
1 - 2 of 2 Posts
