Anyone know the correct fork stem torque setting on an '04 VRSCA? I've seen 45-55 and 70 ft lbs. I don't want to under or over tighten.
It depends on what hardware you have.Anyone know the correct fork stem torque setting on an '04 VRSCA? I've seen 45-55 and 70 ft lbs. I don't want to under or over tighten.
Steve,It depends on what hardware you have.
The OEM nut (45718-60), locking washer (45717-63), and Al alloy stem can only be tightened to 45 to 55 ft•lbs.
This lower torque has been a problem for many HD models that used this combination of hardware (front end clunk) so a new flanged nut was made available in a kit (45736-07). This flanged nut (without a locking washer) can be tightened to 60 to 70 ft•lbs.
The other combination is the 45718-60 nut and 45717-63 locking washer on a steel stem. Steel stems were used on the lower chrome triple clamps (46752-01A, 46771-02A, 46788-06A, and 46860-06A) and lower triple clamps made in 2008. This nut, washer, and steel stem combination can be tightened to 80 to 90 ft•lbs.
All VRSC models from 2009 on use a different upper triple clamp and stem that use a bolt instead of a nut.
I'm saying that the unflanged nut (45718-60) on the steel stem can be torque to 80 to 90 ft•lbs. The steel stem and flanged nut (P/N 8193 that's only available in the 45736-07 kit) can be torqued higher but HD never mentions this combination so I'm not sure what that would be, maybe 110 ft•lbs.... I recently replaced my aluminum shaft with the ungraded steel one. Prior to this I upgraded "The Nut" to the mentioned kit, (45736-07). When installing the new stem and lower triple I torqued the flanged nut to the 65lb spec mentioned in the kit.
Are you saying I should be torquing it to 80-90 lbs?
My fall-away is in compliance but I still get an occasional clunk.
