One of my forks is leaking.I had them coated and put a lowering kit in them.No problem there.I think! It's leaking from the pipe seat bolt.The one in the bottom of the tube.I've taken it off 3 times and checked to see if tight and it;s tight as I can get.My ? is can I wrap teflon tape around to bolt and reinsert it or and other suggestion.I have the washer on that was on the bolt .First thing I checked.REally ticking me off though.Getting lube on my new wheel!!!
Registered USDA
The pipe seat bolt should have a washer also. Are you sure it is there? I would get a torque wrench and make sure it is tightened to spec. The issue with teflon tape would be if it comes off the screw it will be in the fork oil.
2" of dangling death
try a new brass washer
I can get the new washer from HD? If so I will be getting 3 and replace both just to be safe!
