1 - 15 of 15 Posts
What will happen, when i forget my jiffy after starting? When i drive thrue a curve, will the stand go to the normal drive position or will it touch the street and will loose control over the bike?
Who knows? Teppo
Teppo the design of the jiffy stand should let it kick back after it makes light contact. I wouldn't want to test it just to see however.
Max
V-Rod Addict
Do it once or twice and you'll have a reason to replace it with a chrome one!
I have done the opposite, forgot to put the jiffy stand down when I got off. Trust me…You don’t want to do that either. Not a pleasant experience. Fortunately it was my old bike and not my new V-Rod. I did add a new meaning to the term DUMB A$$. :spank:
Registered Confuser
DUUUUDE.......
On Jap bikes it typically flips up
I have seen a number of real bad H-D accidents when you forget the big twin/sporty type jiffy stand.
Never seen a VRSC leave one down yet.
Probably not too good though.
Duc's fly up -------sometimes when you prefer them NOT to have popped up.
BobT
SNAFU
On bikes that don't have the two position stand like ours I thought that federal law requires a neutral safety switch be installed but after a cursory search of the DOT website I can't find the regulation. It seems that every bike I've had since the mid '90s that has a kickstand that locks in the down position has had a neutral safety switch that causes the bike to stop when it's put in gear. On the Harley's and other bikes where the stand only locks in the down position when there's weight on them they don't have the switch. I personally think it's a good thing to have on all bikes but that's just my :2cents:
Rather than add more unnecessary stuff to the bike----Just remember to put it up yourself. Once the weight is lifted off, the jiffy stand will raise up if it's tapped. I don't think you will have a problem wrecking the bike in a left turn. :2cents:
yes, it would be nice to have an ignition interlock, or indicator light, or warning buzzer, or something like that for the kickstand... but then.. you have to shell out 9000-11,000.00 for a truly well engineered Metric bike to get that..
hey.. I love these things.. but I not so blinded I think they're engineering marvels.
'02 V-Rod #1910
It'd be nice if the starter would only work when in neutral or with the clutch disengaged. i've had a few close calls with my 'rod as I've become accustomed to rice burners. I'm sure I'll figure it out one of these days :chair: (hopefully without incident)
1 - 15 of 15 Posts
