1 - 9 of 9 Posts
Burn Baby Burn!!
I am using the Force map that Power Commander has on it' s web site. The bike seems to run like a banshee out of hell but MAN is there some decel popping to it. I would occasionaly get a pop or 2 from the vmod map with these but nothing like this. Anyone running a modified PCIII Force map without all the popping? If so which one are you using? I am considering having it dynoed but if anyone can help with this it would be much appreciated before I spend the bucks on a dyno. Figured I would ask the pros on here first.
VRF0RUMS ORIGINAL
Until you get it on a dyno. You could add 1-2% more fuel from around 6000rpm down to 1200 rpm @ 0% throttle. It'll help with the popping until then.:thumb:
Dilligaf
Post your map and we can check it out and maybe tweek it a bit.
VRF0RUMS ORIGINAL
KCK_Fireman said:
I am using the 024 map from the PC web site.
Here you go give this a try. I added 2% MORE fuel from 2000 rpm up to 6000 rpm @ 0% throttle position. Then, I again added 2% MORE fuel from 4000 rpm up to 5000 rpm @ 2% throttle position. This should knock some of the decel popping out.:D
VRF0RUMS ORIGINAL
Spaz said:
If that still pops try this one. Also make sure you zero the throttle position.
Your right! If my change in the map dosen't suit him, yours will! Thats a lotta fuel down low.
Dilligaf
That's usually what it takes to stop the popping, it's either go that route or go -99 and completeley shut off all the fuel in the zero column.
Burn Baby Burn!!
Thanks very much guys! I am at the fire station today so I' ll have to try it out tomorrow. Man I love this forum! I did make sure I recalibrated the throttle before I installed the map, and I' ll do it again on this new one just to make sure. Thanks again.
1 - 9 of 9 Posts
