1 - 2 of 2 Posts
Hi all knowledgeable people! Need help figuring out why the main beam lamp on the dispenser lives his own life when turning on the ignition? it flashes I installed led beams 4 months ago and this started 2 weeks ago. I have tried everything I think. If cables and connectors were removed and cleaned, tried out when the cables are disconnected but the problem persists, there may be something with the data box, having tried with two different led lamps the same problem on both, tested with the original lamp then it was normal. is anyone knowing what it might be wrong?
It is fairly common to get moisture in the instrument cluster. This can lead to intermittent lights in the cluster. With any luck it will try up and the problem will go away.
1 - 2 of 2 Posts
