1 - 3 of 3 Posts
Picked one up used on the forum and wondering if anyone still has the installation instructions. Looks like it would be an easy mod but just want to be sure.
Thanks!
Let me see if I can recall without the bike in front of me.
Remove pulley cover & belt guards
Loosen all pulley bolts & rear axle bolt
Lift bike
Loosen axle bolt so you can move tire forward
Remove pulley bolts & remove pulley (belt should be loose enough)
Install 26th tooth pulley & tighten bolts (snug)
Adj. Rear tire/belt & tighten (snug)
Drop lift but not all the way, just enough so you can torque the bolts & axle
Torque pulley bolts to APPRX. 70 ft. lbs
Torque rear axle APPRX. 150 ft. lbs
I would ride it for a few miles then check the torque then install the guards.
1 - 3 of 3 Posts
